Play in R/F Wheel
Postby Adamal » Wed Jun 30, 2010 11:59 am
CXGPWR wrote:Play in wheel?? Take the weel off and see if there is any movement in the wheel - i can allmost promise that there will not be any "paly in wheel"
Haha I'd love to see a WOF sheet that says "Lots of play in the wheel and very wobbly when not attached to vehicle"
Postby rollaholic » Wed Jun 30, 2010 1:31 pm
how can you fail a wof for a wobbly wheel if its not attached to your car?!
that could be anyones wheel mister...
as others have mentioned theres four or five things that could be causing 'play in wheel' good plan to work out which it is before spending.
Postby Jingle Balls » Wed Jun 30, 2010 2:29 pm
well, after a few calls, i bought a new rack end, and tie rod end, for the whopping sum of $45 including freight. hopefully one of these fixes it. if it's the wheel bearing as suggested earlier, they're quite expensive apparently. my girlfriend's dad who is a mechanic will be helping me fix it. although he does not know this yet.
Jingle Balls
Postby Adamal » Wed Jun 30, 2010 3:00 pm
rollaholic wrote:how can you fail a wof for a wobbly wheel if its not attached to your car?!
Because as CXGPWR pointed out, the wheel is a seperate item, and its highly unlikely that the wheel has any 'play' in it.
I was mearly making a joke, which I'm guessing was not obvious to you. You're not German, are you? :P
Postby Malcolm » Wed Jun 30, 2010 3:38 pm
Jingle Balls wrote:well, after a few calls, i bought a new rack end, and tie rod end, for the whopping sum of $45 including freight. hopefully one of these fixes it. if it's the wheel bearing as suggested earlier, they're quite expensive apparently. my girlfriend's dad who is a mechanic will be helping me fix it. although he does not know this yet.
wheel bearings aren't too bad, just don't buy from repco. I usually go through bearing wholesale and IIRC they're usually around $50-70. Changing them isn't too bad if you have access to a press + angle grinder and at least kinda know what you're doing
Postby rollaholic » Wed Jun 30, 2010 4:14 pm
i was trying to indulge your joke! too dry? internetz ftl. the whole idea is clearly laughable...
man i wish i was german.
Postby Adamal » Wed Jun 30, 2010 4:19 pm
Text is such a poor medium for humour sometimes :(
Postby Scottie » Wed Jun 30, 2010 9:07 pm
Adamal wrote:Haha I'd love to see a WOF sheet that says "Lots of play in the wheel and very wobbly when not attached to vehicle"
I laughed :D +1 funny point each
Scottie
Postby Crucible » Wed Jun 30, 2010 11:26 pm
Gudgen wrote:"play in wheel" could be anything. WOF inspectors aren't there to diagnose the fault, just to inspect.
Maybe if you work at a testing station.
if you have play shacking the wheel vertically back n forth, its more likely to be a wheelbearing or balljoint, use a pry bar under the wheel and get underneath with a spotty. if you feel play from side to side movement its more likely rack end or tie rod.
put your hand on the rack boot and grab the knuckle/shaft between your fingers, get someone to move wheel side to side, you will clearly feel the movement if its rooted. shine the torch on the tierod boot while youre at it. The pressed part of tierod will be moving away from the boot if it is. sometimes the movement will be there under load (wheels on ground).
If its a wheelbearing youl see the wheel only rock if you look from the inside. Try tighten first with a rattle gun before you replace it.
Crucible
Real Life Mechanic
Postby Jingle Balls » Thu Jul 01, 2010 9:54 am
mine was a side to side motion. i felt it myself
Jingle Balls
