pinking problem
Postby sergei » Fri Sep 10, 2010 7:48 pm
MAGN1T wrote:Motors don't "carbon up", never have done.
Oldschool V8 guys used to run leaded fuel, as everything did. The "carbon" is actully lead, It doesn't happen any more or if it does, it's because it's been burning lots of oil & needs a rebuild.
Steve
Actually they do, since you are mitsi guy you should know better about those GDI engines carboning up to their death.
Postby sergei » Fri Sep 10, 2010 8:05 pm
Postby MAGN1T » Fri Sep 10, 2010 9:26 pm
GDI motors "carbon up" due to the EGR, same reason Diesels do. Because the rings are worn, the oil vapour from the exhaust goes back into the intake and condenses on the walls.
Seafoam doesn't work........ theres a thread about it's "fail " on msport. It's just one more of the many sales scams you get with cars.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby sergei » Fri Sep 10, 2010 9:29 pm
MAGN1T wrote:GDI motors "carbon up" due to the EGR, same reason Diesels do. Because the rings are worn, the oil vapour from the exhaust goes back into the intake and condenses on the walls.
Steve
Yeah, I wasn't sure about seafoam, I posted that as a pictorial of examples of carboning up.
I have seen various non-egr cars carboning up as well (including 20v).
Postby QikStarlie » Fri Sep 10, 2010 9:31 pm
Steve
but lead coating isnt a bad thing. you'l find it was the quality of the fuel back then. dumping lead in it made it better, but if it wasn't refined as good as today's fuel, plus rich mixtures and poor combustion = carbon build up
so in other words if your new school car is doing it. is not running right, or someone tipped sugar in your fuel tank etc..
you could try thrashing the shit out of it, using the old excuse of "blowing the carbon off the pistons" for lols, if pouring water in the engine doesn't do it for ya
QikStarlie
Postby Skin » Fri Sep 10, 2010 9:50 pm
you realise its a 7afe? ringing the nuts off of it still wouldnt attract the attention of the po-leece over here!!!
Gonna try pouring boiling water down the intake over the weekend, see what happens.... :lol:
cogent wrote:iPhones can eat a dick.
1981 Mazda RX7
1997 Toyota Corolla
Skin
Postby metal_sean_head » Fri Sep 10, 2010 11:09 pm
Skin wrote:you realise its a 7afe? ringing the nuts off of it still wouldnt attract the attention of the po-leece over here!!!
Video proof please!
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby Dell'Orto » Sat Sep 11, 2010 1:35 pm
It works alright actually, just dont go dumping a litre into the intake in one hit :lol:
Ever seen the inside of a motor thats been running water/meth injection?
Postby MAGN1T » Sat Sep 11, 2010 3:04 pm
It depends on the CR of the motor. Some 7AFEs are 9.5 to 1 so you really wouldn't want to run it on anything other than 98.
Yes WI keeps them clean but nowhere near as clean as CNG or LPG.
Steve
MAGN1T
Postby Mr Revhead » Sat Sep 11, 2010 3:33 pm
Bs :!:
Postby Crucible » Sun Sep 12, 2010 11:01 am
A guy I used to work with few years back was right into the stock car scene, he had a valiant running on methonal and reckons he had to switch it back over to petrol, run it for half an hour or so after a meet otherwise the bores would go all rusty.
Crucible
Real Life Mechanic
Postby sergei » Sun Sep 12, 2010 10:44 pm
All alloy parts will be corroded badly after running water/methanol injection for prolonged periods.
Postby Dell'Orto » Sun Sep 12, 2010 10:47 pm
Yeah, running the motor on methanol is a bit different...it is a very effective solvent so not surprised it'd rust up bores!
Postby QikStarlie » Sun Sep 12, 2010 11:06 pm
MAGN1T wrote:It depends on the CR of the motor. Some 7AFEs are 9.5 to 1 so you really wouldn't want to run it on anything other than 98.
Steve
haha @ 9.5:1 compression ratio needing 98 octane.
QikStarlie
Postby Skin » Mon Sep 13, 2010 1:46 pm
Lol, i probably should of made it more clear i was kidding about pouring water into the engine, shes my daily, no way im doing something as risky as that!!! And yeah, i somehow doubt an australian market car, made in 1997, needs 98 octane to run correctly :lol:
I have a theory, tell me what you think. It appears the car is burning quite a bit of oil, which is fair enough considering its done 316k. Could it be this excess oil which is preigniting the fuel, or perhaps contaminating the fuel enough that its lowering the octane rating? Im going to pour some stop smoke into it, try and gunk up the piston rings a bit more.
1981 Mazda RX7
1997 Toyota Corolla
Skin
Postby Mr Revhead » Mon Sep 13, 2010 1:50 pm
Yep, could very well be that.
blow by causing excess oil vapour to be pushed through the pcv system and into the air intake will do that.
Pull the intake hose off and see if you have a lot of oil residue in there.
Postby RS13 » Mon Sep 13, 2010 3:51 pm
Mr Revhead wrote:Yep, could very well be that.
Seconded. Maybe even rangi up an oil catch can with a coke bottle or something, see if that makes a noticeable difference.
RS13
Postby Skin » Mon Sep 13, 2010 4:01 pm
Haha, rangi. The looks i get here when i use that in a sentance are priceless :lol:
1981 Mazda RX7
1997 Toyota Corolla
Skin
