suspension walk
Postby Mr Revhead » Wed Dec 29, 2010 1:09 pm
Malcolm wrote:
DexGT wrote:Drive flange is the thing that has the wheel studs in and the spline for the CV to go thru. It goes inside the wheel bearings in the hub.
The part you call a drive flange is more correctly known as a hub. The part you call a hub has about a billion different names, but upright or steering knuckle are some of the more common ones
Yes..... And people moan at us parts guys when we order the wrong part.... :x
Postby tsoob » Wed Dec 29, 2010 2:20 pm
I just removed the front strut (drivers) and the shock has plenty of spring back left in it, better than the other ones i have here.
I wonder if its in the steering rack... if i chop down to say 3rd from 4th on the open road to overtake, as it comes on boost the car just rocks left to right and i have to fight it with the steering wheel.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Adamal » Wed Dec 29, 2010 2:21 pm
What are the bushes like holding the rack in place?
Postby tsoob » Wed Dec 29, 2010 2:24 pm
85AW20v wrote:And check the back end as well as the front. Flogged rear bushes could cause "realignment" under acceleration too.
the rear bushes on the longer arms have a fair bit of play in them... thats concerning
also the rear sway bar is tiny compared with the front one and there is a bit of play where the links mount up.. maybe the front one is out working the rear one?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby tsoob » Wed Dec 29, 2010 2:26 pm
Adamal wrote:What are the bushes like holding the rack in place?
fine, the rack has no movement at all. no visible leaks either.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Malcolm » Wed Dec 29, 2010 2:38 pm
The sway bars should only really effect balance in cornering (and the slopiness will just make it a bit shitty/unpredictable), however the play in the rear control arms could definitely be causing/contributing to the symptoms you've described
Postby Mr Revhead » Wed Dec 29, 2010 5:15 pm
When you say "rocks left to right" That to me says it feels like someone grabbing the roof and rocking the car. I cannot imagine anything that would cause that.
Postby siren676 » Thu Dec 30, 2010 12:06 am
Stop driving when its windy?
siren676
Postby 85AW20v » Thu Dec 30, 2010 11:09 am
tsoob wrote:Torque steer... possible, but I have a very very tight lsd, it just hooks up and goes.. and this has just started happening lately, and its getting worse.
Could also be that one side of the LSD has worn more than the other, putting all the grip/torque through to one side.
See ya
Simon
85 MR2 20v
85AW20v
Postby BZG Wagon » Thu Dec 30, 2010 11:54 am
I know I'm preaching to the converted here... but I once had something similar happen when I had a sh*t pair of tyres with substantial wall movement on my car.
Oh - and another time when my trailer had somewhat deflated tyres - they just looked inflated because they had minimal load on them.
Would it be worth trying a different set ot tyres to see if the problem changes at all?
BZG Wagon
Postby tsoob » Fri Dec 31, 2010 2:48 pm
yeah im sure its not torque steer, the gearbox was apart less than a month ago and was all fine at the time.
Tyres... nice try :D I never have tyres on my car go under 1/2 tread, i just sell them as secondhand tyres and put a new set on my car haha
Im pretty sure it will be those 2 rear control arms that i found to be loose the other day, when i get back from the mount ill put it back on the hoist and change them to noelathane and report back..
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby touge_ae101 » Sat Jan 08, 2011 9:04 pm
any word on this nick?
i have got the same problem and its kind of annoying. from reading above i also suspect the rear control arm bushes as those are the only ones on my car that haven't been recently done with nolathane.
touge_ae101
Postby tsoob » Wed Jan 12, 2011 1:00 pm
Yep i replaced the control arm bushes and its a lot more stable. still not perfect but is a lot nicer now!!
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby tsoob » Wed Jan 12, 2011 1:08 pm
you can see there was a lot of movement, i forgot to take photos with the noeletahne in there but there is bugger all movenment now!
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby touge_ae101 » Wed Jan 12, 2011 5:23 pm
ahh sweet did you just replace the rear?
touge_ae101
Postby tsoob » Wed Jan 12, 2011 6:09 pm
touge_ae101 wrote:ahh sweet did you just replace the rear?
i only did the upper inner rear, not even the ones that go to the hub. will replace all the otehr ones at some stage. the fronts are already done.
can supply you the kit if you need it bro
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby XSVWGN » Wed Jan 12, 2011 8:41 pm
what was the kit worth out of curiosity?
2008 Kia rio - work car
XSVWGN
Postby tsoob » Thu Jan 13, 2011 12:13 pm
around 80 bucks bro
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Bazda » Thu Jan 13, 2011 3:37 pm
Sounds a bit like torque steer as well to me.
And having suspension which is sloppy will make it worse.
Check your alignment again, you had the front end apart various times and most likely the alignment has changed quite a bit.
Postby tsoob » Thu Jan 13, 2011 10:03 pm
Bazda wrote:Sounds a bit like torque steer as well to me.
yeah, i made a bit of a mistake with a set of coilovers i sold for an ae82, so im gonna have to take them back....
Oh well guess ill just chuck them into my car :D
will check wheel alignment once those are in and new rubber goes on
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
