dnalunchie wrote:Nar.... I need boost or lots of revs.
cogent wrote:dnalunchie wrote:I am having performance car withdrawel issues. I need boost or revs or something!
lend you my rx7 for a week in exchange for a hoon on ya sis?
Flannelman wrote:When a cam is "reground", the base circle is ground away by a certain mesurement.
To increase lift by 2mm, the base circle is ground down 2mm. This also raises the duration of the cam to a given degrese. If the valvetrain has no way of taking up this 2mm in lash, then very expensive things need to be done to set the lash - offsetting the price of a regrind.
I dont know anything about a Suzuki Swift engine, but if it has the adjustment it could be worth looking at the price for a regrind. If not, dont bother.
strx7 wrote:how can you easily lengthen a valve?? youd need to pull the head off, disassemble it all, find some longer valves, balh blah blah.
