are all cam belts equal
Postby Dell'Orto » Wed Jan 19, 2011 10:52 pm
h8wrxs wrote:so is $400 about right for a cambelt kit from repco, i think it was a gates belt it some with?
or can anyone recommend somewhere/ sell me a kit cheaper?
$400 sounds about right, those mitsi kits have the balance shaft stuff in them too.
Postby h8wrxs » Wed Jan 19, 2011 11:04 pm
sweet im sold then, cheers for the info as always :D
h8wrxs
Postby fivebob » Thu Jan 20, 2011 7:44 am
iOnic wrote: Using an OEM cambelt on a 10,000rpm 4G63 (for example) is just asking for trouble. At those sort of revs there is so much stretch in the belt that you start getting inconsistent triggering and sync between the crank and cams when using a weaker belt.
You'd think that high RPM would be where the belt is under the most strain, but it's not, it's at idle ;)
Postby sergei » Thu Jan 20, 2011 10:29 am
Especially with bigger cams and stiffer springs.
Postby Bazda » Thu Jan 20, 2011 11:02 am
I've had a gates belt which had a wobble. Didnt run straight. Sent it back and just bought an OEM belt.
My dad has seen this a few times as well as he has been buying gates for 30 years.
So you gota be carefull!
For Toyota stuff I just stick with OEM its its nearly the same price.
Postby iOnic » Thu Jan 20, 2011 8:32 pm
fivebob wrote:You'd think that high RPM would be where the belt is under the most strain, but it's not, it's at idle ;)
I know that. But it's also common knowledge that using weaker OEM belts can result in inconsistent timing at significantly higher revs due to stretching. Seen it several times when tuning engines that fall into the above category. The point I was making is that stronger belts aren't just for wank factor - they do serve a purpose ;)
Postby rollaholic » Fri Jan 21, 2011 8:09 am
i've always prefered gates over toyopower. never had a problem with them. OE for toyotas, dunno how mitsi prices stack up though.
toyopower are generally a bit cheaper
Postby sark.inc » Fri Jan 21, 2011 11:46 pm
http://www.gates.com/brochure.cfm?broch ... &go=TBHome
Gates warranty is for the factory change interval.
sark.inc
