idea is to make a airbox that can squeeze between the engine and the battery without having to relocate it. best thing would be to get a bit skilled up TIG welding or get freindly with a fabricator and swing a few boxes of beers their way.
way to do it is to measure up the space you have between the battery and the coil packs. (could rotate battery a bit to give extra room) and then go down to your local parts store and give them a challenge that only their smartest 17yr old pimply faced wanna be mechanic will be able to sort for you - if your lucky that is. anyway go through their stock of panel filters until you find the biggest one possible that will fit into that space. then start designing your airbox around that. cardboard will show you the best way of figuring out dimensions and constraints or the use of CAD also helps as a mock up tool. from there it is simple. keep biggest volume of 'filtered' air available close to the engine, this will give your car good response and not lose any torque. i would say this will give a much better result than a factory box (so up yours to mr toyota and their millions of $$ of research!:wink: )
keep the front of the filter enclosed and bring it down to a opening that you can fit the biggest-bit-of-flexi-hose-you-can-find over and jam this right in the front bumper where it will get plenty of fresh air (fog light perhaps)
this will make your engine bay look bling and be very practical in making moar power! even get it made out of alloy for lightweightness if you can find someone to weld it for you. only thing you may want to do is get some heat sheild to stop the hot air from extractors warming up the airbox too much as both alloy and stainless conduct heat quite well.
i've been pondering this design for a while and i got the idea off a TOM's carbon fibre intake thingy i saw on a touring car with a silvertop in it. it looks like they are about the same dimensions so you could sell to 4age people too.
so if you actually develop an airbox, i'm sure there could be people out there willing to pay the $$$ for it if its dyno proven.
if i didn't already have a mac daddy airbox i would of done this by now.
edit: oh btw blue is filter, orientated as a vertical rectangular shaped non-descript ms paint object, and red is the outline of the box (also badly drawn) but hope you can see what i mean
