328FTW wrote:...this time there was just no good reason other than something is really wrong here
Mr Revhead wrote:Ok, so you are taking known good running longblocks, putting a turbo etc on them and in very short time they seize?
Have we established exactly what way they are seizing? I'm reading bearings and piston expansion, which are caused by different things...
328FTW wrote: before going to the track. Get on it for extended time at very high revs and bad things happen.
- sounds like the ideal recipe for disaster doesn't itRS13 wrote: you're slapping a turbo setup onto a tired n/a 3S, throwing it around corners at massive RPM with no modifications to the factory oil system..
rollaholic wrote:if it were starvation you'd think you'd still get some death rattle before it shit itself entirely though
levinguy wrote:how much money have you spent throwing at standard motors that you've blown up? spend half that on a proper engine you build from scratch with an oil system that will cope with racing.. problem solved?
standard motors aren't designed with boost in mind to be revved excessively around a track, feel free not to listen, but yeah, wait for the i told you so.
to me it seems a bit ridiculous what you expect from a standard non turbo motor in a road going car..
