4agze missing/no power :(
Postby mr30%jr » Mon Mar 07, 2011 8:52 am
328FTW wrote:If you take it in have them time the motor to 10*BTDC as well. Timing is a big factor so you will want that to spec. Sounds like it needs maintenance items like that doing.
and make sure thats done in test mode....with it warmed up otherwise it will be static and wont mean a thing
mr30%jr
Postby KIPH8N » Mon Mar 07, 2011 7:33 pm
TRD_ZERO wrote:
KIPH8N wrote:
AE92-5ONIC wrote:http://www.troublecodes.net/Toyota/
looks quite confusing :(
Go in the enginebay look for a small black box that says diagnosis. Open it up. grab a paper clip or any sort of wire and jam one end in the terminal TE1 and the other end in E1 (there should be some sort of labeling as a reference). Now go and turn ignition on so that the lights come up on the dash eg.oil, brake, check engine light etc. Dont start the car.
follow the easy instructions below
Count number of flashes from CHECK ENGINE light.
If system is operating normally (with no detected faults), the CHECK ENGINE light will blink continuously
and evenly about 2 times a second.
Otherwise, the light will blink a number of times equal to the trouble code as follows:
The light blinks only (.5 second ON, .5 second OFF) when indicating a number.
The light will be OFF for 1.5 seconds between the first digit and the second digit of the code.
If more than one code is stored, the light will be OFF for 2.5 seconds before the next code is displayed.
Once all code(s) have been displayed, the light will be OFF for 4.5 seconds and then the whole sequence will repeat.
The diagnostic code series will continue to repeat as long as the check connecter terminals TEl and El are connected.
When finished, remove the jumper wire.
Its that easy.
You might have to do the count a few times to make sure you have the correct codes.
Get into it and start learning how to do some shit yourself.
The check engine light blinks continuesly so means nothing is wrong
KIPH8N
Postby KIPH8N » Mon Mar 07, 2011 9:01 pm
Thanks guys it was just the spark plugs. lol
It doesn't miss any more.
But havn't taken it on the road yet because got no w.o.f n rego on hold.
KIPH8N
