neo wrote:Jaycar frequency switch... $45 http://www.jaycar.co.nz/productView.asp ... rm=KEYWORD
is there no speed signal going to the ecu at all in the old mr2's ?
could get funky and use a abs sensor signal...
Dell'Orto wrote:Warwick - trying to avoid running 100% to help prolong pump life. Will only use a Legacy pump to begin with.
Dell'Orto wrote:neo wrote:Jaycar frequency switch... $45 http://www.jaycar.co.nz/productView.asp ... rm=KEYWORD
Yeah think there is, but the gen 1's are cable speedo. Though actually, the power steering is speed sensitive, so it must take a signal from somewhere. Could use that to switch by RPM
matt dunn wrote:Do you realise that stop starting a pump all the time
is a lot harder on the pump than running it all the time...........
Mr Revhead wrote:Failed intercooler pump won't cause your engine to overheat or your turbo seals to fail.
gt4dude wrote:matt dunn wrote:Do you realise that stop starting a pump all the time
wouldn't think so on an electric motor?
