ae101 levin brake upgrade
Postby h8wrxs » Thu May 19, 2011 8:56 pm
vr4boy wrote:cool lots of help guys, ill look into getting some new pads for now and see how it holds up, is it easy to replace brake fluid? ive done most things to cars, just never fully replaced brake fluid.
yeah really easy
just bleed your brakes as you would when changing pads, but bleed out all the fluid, and refill it with new when you put it all back together
h8wrxs
Postby wde_bdy » Thu May 19, 2011 9:18 pm
For replacing ALL the fluid you really need professional gear, since I'm a lazy $&#$% I just paid Pitstop to do it with their proper machines. Far far easier than doing manually.
Callum
wde_bdy
Postby vr4boy » Thu May 19, 2011 9:19 pm
sweet, thanks, so empty it all out before i put new stuff in?
1995 ae101 levin st 20v
vr4boy
Postby Bling » Thu May 19, 2011 10:07 pm
I never have, i've always just used the new stuff to flush out and replace the old stuff. Helps if you buy fluid that is a different colour. No issues with air in the lines that way.
Sure it's no pitstop machine, but i'm sure it gives the same result :P
Postby vr4boy » Thu May 19, 2011 10:21 pm
cool, might just flush it through with new fluid then, out of interest what did pit stop charge? and is there any brand that is better to use?
vr4boy
