Akane wrote:jaypines wrote:twincharge... best of both worlds. though havent seen one yet on a 3s.
Because nobody is "reckless" enough to put something that much more complex and expensive for minimal gain.
i know someone thats twincharging a 5sgte
loudstealthGT-Four wrote:Akane wrote:jaypines wrote:twincharge... best of both worlds. though havent seen one yet on a 3s.
LEAKER wrote:Ok cool, I'm thinking 350hp at wheels with full boost at approx 3500rpm as a new realistic goal. I will go link g4 as per the advice, 1000cc injectors, fuel rail, fpr and 264 cams. Unsure of what turbo ill get yet. Is a ball bearing really of any advantage over journal?
Heylin wrote:In the MR2 im running 275 rwhp at the moment on grippy tyres 225/40/17 Falken FK452 on 8" wide rims and can break traction in the dry between 50-80 kmh.
In the wet requires good discipline with the right foot... so yeah 350 is going to be quite mental in a celica, although its an all trac isnt it ? so mabey not.
How? I'm running 292 rwhp with 700nm rwtq, 235/45/R18 and still won't break traction in the dry unless the road is uneven, then it's just a ever slight chirp.
Different story if you don't point it straight though.
Heylin wrote:In the wet requires good discipline with the right foot... so yeah 350 is going to be quite mental in a celica, although its an all trac isnt it ? so mabey not.
Akane wrote:How? I'm running 292 rwhp with 700nm rwtq
RomanV wrote:Akane wrote:How? I'm running 292 rwhp with 700nm rwtq
Your atw torque figure changes depending on what gear you're in.
A 4AGE has probably got 700nm, in first gear. :p
LEAKER wrote:
So what your saying about evo turbos, would a decent hybrid evo turbo be worth a thought?
LEAKER wrote:new thought, at the risk of being shot!
What would hapen if i was to fit some sort of twin turbo setup. maybe 1jz turbos?
