Water in diesel tank
Postby evil_si » Thu Aug 18, 2011 8:33 pm
Generally when talking about diesels the fuel pump and injector pump are one in the same
evil_si
Postby gleem » Thu Aug 18, 2011 10:57 pm
oh ok i assumed so, only ever worked on trasits before that have the fuel pump running of the block feeding the injector pump
gleem
Postby Scottie » Fri Aug 19, 2011 12:22 am
gleem wrote:oh ok i assumed so, only ever worked on trasits before that have the fuel pump running of the block....
call that a lift pump to avoid confusion :D
Scottie
Postby gleem » Mon Aug 22, 2011 11:37 pm
ok say found 3 of the 4 glow plugs were stuffed. removed injectors and they werent flash but i have cleaned them up. not sure about the end caps being blown of but looked like it was all there.
Took lines off. cranked till diesel was spraying out so that seems all good. Water was in 3 of the 4 lines.
Will look for injector rebuild guide on google now.
gleem
