blacktop 4age in aw11 mr2; filling the coolant
Postby CXGPWR » Fri Sep 16, 2011 7:04 pm
touge_ae101 wrote:bleeding blacktops is dead easy with a trick john (CXGPWR) told me, just pull the top heater hose off and run the car for a few minutes with radiator cap off. works 100% of the time in about 2minutes. 8)
Truw for FWD, However in a MR2 its slightly different, as if you arnt careful you will get an air lock in the head, and thats the bit you dont know about till its too late and all of a sudden if will boil over make lots of funny noises and then you try again and find out that you have just cracked your head.....,
Some are easier than others though.
CXGPWR's 1985 Toyota Trueno Racecar Spec
Build Thread
Discussion
CXGPWR
