Vacum leak problem for brakes.
Postby Mr Revhead » Tue Feb 14, 2012 11:16 pm
allencr wrote:I'd NEVER get a thermostat from from the dealer, just like I'd never get wiper blades, battery, tires, oil, alternator, starter, hoses(except for factory only heater stuff), belts, plugs & plug wires!
That TRD thermostat is beyond belief.
http://www.stant.com/Consumer-Products/Thermostats/
Don't forget we are in NZ. Dealers are pretty sharp on a lot of things. Often cheaper to go genuine now. Certainly a good chunk of the time Genuine < After market as far as quality goes.
Postby andyling » Wed Feb 15, 2012 12:56 am
Trd parts yeh really really expensive.
but that's said Toyota dealers are pretty good on most of these small wear and tear products.
Don't expect to get cheap interior and exterior parts for cheap tho. so expensive.
I will check the vacuum line to the brake booster tomorrow.
how do you check the one way valve?
andyling
Postby sergei » Wed Feb 15, 2012 1:04 am
andyling wrote:how do you check the one way valve?
blow in it.
Postby crispy'86 » Wed Feb 15, 2012 8:23 am
blow in it.
Should be able to pass air through it one way and not in the opposite direction, if you can valve is stuffed. Also check the hose has no cracks or brittle parts at the booster or especially the manifold. Even the fitting screwed in the manifold
crispy'86
Postby wde_bdy » Wed Feb 15, 2012 8:31 am
If it revs up when you brake then the valve is fine and the booster is stuffed, the entire point of the valve is to let the engine suck the air out of the booster and then keep it under vacuum. Revving up means it is sucking air past the seals in the booster.
Callum
wde_bdy
Postby Dell'Orto » Wed Feb 15, 2012 6:41 pm
Yeah, will likely be a torn diaphragm in the booster. I have a spare if yours is the PFL type, which I assume it would be.
Postby andyling » Wed Feb 15, 2012 11:23 pm
checked the line and valve, seems to be working ok.
I will see what i could do after I trouble shoot somemore.
it seemed to be fine again, weird.
andyling
