Brake shudder - SOLVED!
Postby Mr Ree » Fri May 25, 2012 5:00 pm
Happy thread is happy :)
wak thud gush!
Mr Ree
Postby rollaholic » Fri May 25, 2012 5:09 pm
i dont see a problem switching the cvs side to side. he just swapped the whole shaft yes? then again i dont see any particular need for it either.
re being stressed to rotate in a certain direction - im fairly sure you'll find they dont sell left and right handed cvs, which would be the case if that were true.
good to hear you got it sorted.
Postby matt dunn » Fri May 25, 2012 10:03 pm
rollaholic wrote:re being stressed to rotate in a certain direction - im fairly sure you'll find they dont sell left and right handed cvs, which would be the case if that were true.
Correct they dont sell a left and a right,
but as they get used they stress in certain directions.
Same with rear axels in a live axel RWD,
it is usually accepted that if you swap them side to side they will snap easier under load.
