BZG|Bling wrote:Both probably You can't usually modify things like springs. Haven't looked recently though.
I just think you either
a) have to be happy with the current height
b) do it right with new coil overs as they are the only way to get an exact height easily.
Dell'Orto wrote:Kiwi-Corolla wrote:What sort of ballpark figure would I be looking at for custom made springs? Compressing my current Super Lows is going to cost $50 a spring, so $200 for the set. If the price is somewhere near that figure to get a set of custom made springs made then it might be worth considering
Probably double that. Advantage is that you can say I want them to be xx height and xx poundage.
Lloyd wrote:You're going to f*ck your car. Save and do it properly, or don't do it.
The best option is adjustable, which requires money and a cert. Adjustable height suspension requires a cert no matter what your clearance with the ground. Any suspension height modification that puts your car less than 100mm from the ground requires a cert, compressed springs, replacement springs, whatever. If it is low it needs cert, if its has height adjustable suspension it needs cert.
Shortening shocks doesn't mean you don't need bumpstops. Sure, the internals of the strut may not bottom out, but all the bits on the outside of the strut will likely be the next thing in line to have a meeting and break things. Adjustable stuff generally doesn't need bumpstops so much as they're fairly stiff springs and the body of the strut itself is shorter than the standard item so you have a lot more room to work with.
wde_bdy wrote:If you read through the WoF requirements compressed springs or shortened shocks both require cert so you really aren't achieving what you want anyway.
Callum
spoonza6 wrote:There are some finer details you shouldn't investigate that you know is going to just annoy you.
Give it a thatlooksright measure, walk away....
Come back look, still low riding, walk away
Unless it bothers you too much do as what everyone has suggested, bazda coil overs n cert.
What's the total figure of all the suspension components you have bought up to today? Include any labour n that you paid for, wheel alignments n such
