Leon wrote:Drive car.
Will become VERY obvious when accelerating out of low speed corner if car has working LSD or not.
/shrug.
iOnic wrote:Enter a corner at low speed in low gear. Bury right foot. Soon know if you have an LSD or not
touge_ae101 wrote:the c56 lsds are a viscous type which tbh doesn't really work like a lsd unless both wheels are loaded evenly.
touge_ae101 wrote:plate type/trd diffs are the best thing in the world to do to your fwd makes them handle and drive amazingly. throw standard lsd away...
sergei wrote:torsen is much nicer than plate on FWD.
Kiwi-Corolla wrote:Opinions anyone?
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
d1 mule wrote:yet another case of the answer to your question being thrown in front of you 15 posts ago and you havnt done it and still have no idea.
GO DO A $&#$% SKID = question answered in 5 seconds
FFS
BZG|Bling wrote:I'm surprised you haven't killed this car yet. Won't be long at this rate though, you'll have the proof sitting on the tarmac. Will be easier to inspect in bits.Why do you care so much if it's LSD or not?
RobertC wrote:Did anybody else think "Troll" then they read the reply? Dropping clutch in the dry @ redline with the hand brake on???
But if that is the case, an open diff box would easily smoke up on the spot. LSD would probably drag the car along.
