Sand Blasting
Postby Bling » Fri Apr 26, 2013 3:02 pm
If you have the space to have one sitting around, make one. I did and just copied and adjusted google finds to suit. But it takes up space which I lack and I hardly ever use it. Mine probably cost ~$200-$300 to build (long time ago now), which included MDF, garnet, a bathroom extractor/light setup, sand blast gun and other bits and bobs.
Postby wde_bdy » Fri Apr 26, 2013 3:47 pm
fangsport wrote:what is the blasting rate up your way??
looking at $240-ish/hour down here......unpainted
If you are not in a big hurry for the bits many owner operated places will chuck them in with a larger job or between big jobs. Seems the cheapest way if you are happy to wait and can speak to the owner. I had the whole underside and inside of a car done that way.
Callum
wde_bdy
Postby fangsport » Fri Apr 26, 2013 11:26 pm
Grrrrrrr! wrote:Standard rate is 2 boxes. Blasted but not primered.
bang on. my kind of currency 8)
fangsport
Postby d1 mule » Sat Apr 27, 2013 1:29 am
a good mate of mine just got his KE70 blasted everywhere bar exterior panels including the roll cage and underneath (was dropped off as a completely stripped shell on a rotisary ) even did bits like the diff housing etc for $400.
d1 mule
Postby Audi » Sat Apr 27, 2013 8:38 pm
Hm, so recommendations for somewhere in central Auckland and cheap? :)
Dig a hole for the next man and you'll fall in.
Audi
