4agze block smashed.
Postby mega4a » Wed Apr 10, 2013 3:26 pm
rats lol i wonder if you could get brand new block from toyota? do 20v blocks have oil squirters?
mega4a
Postby Mr Revhead » Wed Apr 10, 2013 4:03 pm
You'll find a block for next to nothing easy as.
Yes they do,
Postby mega4a » Wed Apr 10, 2013 4:13 pm
just need to find a low km 20v block then i guess and put my crank and rods in i guess ill have to replace that one piston.
mega4a
Postby Dell'Orto » Wed Apr 10, 2013 7:10 pm
Do you have a different temp gauge to measure temp? Those vertical score mark would suggest that at some stage it has been and the piston has picked up in the bore. Could be unrelated, but still.
Postby mega4a » Wed Apr 10, 2013 8:32 pm
Dell'Orto wrote:Do you have a different temp gauge to measure temp? Those vertical score mark would suggest that at some stage it has been and the piston has picked up in the bore. Could be unrelated, but still.
i have two one for mega squirt and one that goes to dash. has been what?
mega4a
Postby Lloyd » Wed Apr 10, 2013 8:40 pm
Hot. I wondered too when you said it had been all machined and there are obvious marks in the bore
Postby mega4a » Wed Apr 10, 2013 8:44 pm
mega4a
Postby mega4a » Wed Apr 10, 2013 8:45 pm
those are the other three. as you can see the block is quite rusty
mega4a
Postby mega4a » Wed Apr 10, 2013 8:58 pm
i think the scoring would just be from fine bits of metal from when the chunk of metal broke..
mega4a
Postby Mr Revhead » Wed Apr 10, 2013 9:00 pm
No, I don;t think it's that kind of scoring
Looks to be a pretty even pattern there. If it was metal it would be a mess and all over the place.
Plus, how would it get there in all cylinders? Also oil would be full of shavings
Postby mega4a » Wed Apr 10, 2013 9:04 pm
mhmmm im not sure what the scoring is from then. number 4 looks to be allgood but 1 2 3 have scoring
mega4a
no water in 4 either.
mega4a
Postby Dell'Orto » Wed Apr 10, 2013 9:16 pm
I bet if you strip it down the pistons will have shrunk too...how long was it running pre tune?
Postby mega4a » Wed Apr 10, 2013 9:33 pm
b4 tune 20,000 km
mega4a
Postby Dell'Orto » Wed Apr 10, 2013 9:38 pm
Number 4 is the clean one? Be interesting to see the state of the pistons when you pull it apart
Postby tuff86 » Thu Apr 11, 2013 7:19 pm
Do you need a ze block? I may be able to help you.
Current: AE86 Corolla GT, Hyundai Veloster Turbo & Santa Fe
Previous: Lots of Toyotas and a few others
tuff86
Postby 4agtepwr » Thu Apr 11, 2013 9:04 pm
Those scores are from foreign material making its way into the engine via the air intake or the engine not being cleaned properly when it was assembled , not the result of a heat related seizure.
A heat seizure will show across the pin bosses of the piston as that's where the most material is in the piston so with excessive heat that's where there is the most expansion.
Looking at that block i'd say it's due to it being so corroded, that has weakened the bore significantly. Boost is kind of irrelevant, cylinder pressure isn't but if it was making 240hp on 18 psi then cylinder pressure wouldn't have been that high. I'm going to say it was a tired old block that hasn't been looked after.
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby mega4a » Thu Apr 11, 2013 9:15 pm
yes i would also agree just bad block the water galleries look very rusty too.
just bad luck i guess...
mega4a
Postby mega4a » Sun Apr 14, 2013 3:44 pm
new block
mega4a
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 43 guests
