Cam timing question
Re: Cam timing question
Postby allencr » Tue Jan 07, 2014 5:01 pm
cat007 wrote:Smooth idle is a little tricky as without a IAC valve the idle is tricky to get right.
IAC = the little hot coolant controlled thingy on the TB?
It's only a semi-controlled air bypass and it doesn't lean it out, so it has nothing to do with a smooth idle, only its RPM when cold.
Move the distib. for its highest & smoothest, then retard it a bit to be safe & bring the RPM down 50-100.
allencr
Postby cat007 » Tue Jan 07, 2014 5:24 pm
allencr wrote:IAC = the little hot coolant controlled thingy on the TB?
The little air valve that's activated by the stock ECU - has a stepper motor inside to help control idle speed and stability
But anyway - I'll source a puller and make sure the key way isn't buggered - and try and find another crank pulley and go from there.
Postby QikStarlie » Wed Jan 08, 2014 3:59 pm
how to tune your 4k?
set the base where it should be, then tune via ecu software would be better
QikStarlie
