TWSTD wrote:pulled plugs and heres what they look like... distinct rust colour to them - even more than shows in the image... what causes this type of phenomenon?
fivebob wrote:Have you run Octane Booster in the engine? If you have, then it was probably Ferrocine based.
tsenior wrote:Also under inspection the Plug which is far right looking from front of engine bay had oil on it, Whys that? Do i need a Catch can because i noticed oil residue in the throttle body, also oil residue in the turbo intake, Are my seals gone and making my mixture sh*t?
tsenior wrote:ok ill do a compression test, I have seen your posts about ringlandsSo Gizzmo is crap, well thats good to know.. maybe time for a upgrade
, if compression is down on that cylinder, What pistons do you recommend for the caldina?
are forged piston ringlands stronger?
Santa'sBoostinSleigh wrote:my sleigh gets its daily thrashings on 95 octane and i dont seem to have any problems....yet..
fivebob wrote:Santa'sBoostinSleigh wrote:my sleigh gets its daily thrashings on 95 octane and i dont seem to have any problems....yet..
I'm glad you qualified that, because it's only a matter of time if you're running more than stock boost and 95 octane gas on that engine. Stock boost should be Ok though.
