Help. need a twin turbo manifold...
Postby 1598cc » Tue May 24, 2005 5:10 pm
do the 4age. stick some ze pistons rods or whatever, then tune it for 17psi and youll be seeing 300hp+ .. with a turbo of course.
1598cc
Postby matt dunn » Tue May 24, 2005 8:19 pm
We ran in the South Island osca series and my brother actually won it one year. The only NON V8 engined car to ever win the series.
We ran an AE101 corolla with a 1JZGTE in it with almost 500hp and huge torque.
The same car now has a highly modded 2JZGTE and over 600HP,
but the other cars have got so much quicker now and the rules have changed so that a non V8 will probably never win again.
What sort of results are you hoping to get?
Postby scotts2hot » Tue May 24, 2005 8:50 pm
Use your Mark III Supra, the 7MGTE can make a loit of power, the supra has a decent suspension design and since it's a race car you can strip a lot out of the car.
scotts2hot
Postby CozmoNz » Tue May 24, 2005 10:16 pm
Lemmie get this right, you want a carbie, twin turbo, 4age, revving to... 9? making 350-400hp....
A), As said above, why carb?
B), Unless shes a sequencial twin turbo setup, a single turbo will provide max boost and flow at the same rpm.... two smaller turbos will take just as long to reach the same flow capacity as one larger turbo. As long as the larger turbo is to the exact same specification as the 2 smaller.
C), Why???????
D), 7m in a fwd.... you a funny man!, a fwd 7m, dont expect to be turning any corners, youd lose the hole point of using an ae92... they handle well due to their weight distribution (as most cars out there do lol), chuck a very heavy engine in a front of a car, and they have just a hint more understeer.
E), Why???????
G), Wheres F??
F), There it is!, anyway, why not just use an ae86 or something, drop a 4agze in, turbo it, run 25psi on a motec, whamo, you win. >.>. certainlly ALOTTTTTT cheaper
Rayne For President!
CozmoNz
you won osca in a ae101.. sweet..
Postby twin_turbo_4age » Wed May 25, 2005 8:11 am
yeah the 2006 rules are meant to change so that only carb's in gt2/3/4 are only allowed carbs... (they are still deciding on this rule).
I have sort of given up on twin turbos. since everyone thinks it would be pointless.
do you have a website for your ae101 2jz car???
twin_turbo_4age
Postby TrouserFxGt » Wed May 25, 2005 5:58 pm
its run by matt? cronin and looks like it will be up for sale at the end of this season so start saving now.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby matt dunn » Wed May 25, 2005 6:58 pm
TrouserFxGt wrote:its run by matt? cronin and looks like it will be up for sale at the end of this season so start saving now.
So i hear,
for about 2 to 3 times what he paid for it,
an about 1/2 of what he has spent on it.
