RomanV wrote:Just something interesting to note....
An F20c (The 240hp 2 litre NA engine for an S2000) Has a throttle body diameter of 62mm.
Now... How wide is the AW11 throttle body?
It would seem that 62mm throttle is good enough to supply enough air for 240hp, so i doubt that the standard throttle would be a bottle neck for a standard 80s 4AGE.
What is also interesting, is that from memory, the throttle body from my 3sge is 75mm or so... Larger than on an S2000. Weird!
barryogen wrote:RomanV wrote:Just something interesting to note....
size doesn't necessarily matter with regards to throttle body... atleast not until your at the edge of it's limits. you can pass the same amount of air through a small one and a large one, except the smaller one the air will be travelling faster.
check out wikipedea on "d laval nozzle"s and you may see what I mean.
RomanV wrote:A well tuned intake which increases air velocity into the ports will make more power than having the ports open to the atmosphere...
RomanV wrote:It just depends on whether you prefer 'suck' or 'blow'.
Stealer Of Souls wrote:In theory the only thing that changes is the air velocity through different sized pipes. In practice there is also an associated pressure drop. Any pressure drop in the intake results in reduced power.
But I would be surprised if any full open TB created a pressure drop worth mentioning... Unless it was undersized....
RomanV wrote:they look terrible.
Santa'sBoostinSleigh wrote:RomanV wrote:they look terrible.
i'll 2nd that!
An interesting thought relating to this... Although the turbulence may cause additional pressure drop (drag), there are certain vacuum cleaners that utilise this same principle to increase the air speed inside their chambers (dyson??). Their claimed effect is to create a spinning vortex through which the centre draws air at a greater speed than a plain straight section.RomanV wrote:another thing to consider with bends in pipes....
I have run a few different configs through my fluid ... considerably, the air isnt travelling in a straight line relative to the pipe.
I would imagine that this is the primary cause of the extra 'drag' caused by pipe bends.
