ROBODISCO_20v wrote:I was just reading an article in the lates zoom magazine on tuning a Falcon XR6 turbo. They were doing dyno runs after doing the mods like exhaust only(245kW), the adding a piggyback ecu etc. They managed to get 308kWat the wheels. Standard was just over 200kW(The factory rating is only 195kW) Then for a laugh they did a run with the factory air box open so it didn't have to breath through the filter & they got 320kW
Thats an extra 12kW at the wheels just by removing the restrictive factory air box set up! You can pick this mag up from most bookshops etc & read it for your self if you dont believe me.
vvega wrote:turbo cars indution systems are setup very diferent to N/A ones
if you dont know this then you have no hope of knowing whyv
ROBODISCO_20v wrote:vvega wrote:turbo cars indution systems are setup very diferent to N/A ones
Yes but they still work on the basic same principle, the more air you can get in the the combustion chamber the the better it combust.
