sergei wrote:Also, early in TRS they had no harmonic balancer, that is probably why there were a few engine problems. My impression of the whole series, that it was put together in a very hurry, as when it started the cars had cooling problems (they had to add extra radiator), inlet manifold leaks, no harmonic balancers with stock blocks, oil coolers added as after thought cable tied to radiator, the bloody thing did not had cold idle up although they used stock throttle body, bellhousing had cracking problems...and then mix up with ECUs
So In my opinion the engine failure was due to bad planning not to weak engine.
fair enough
