lightened flywheel
Postby Bling » Mon Oct 29, 2007 11:36 pm
commentator made the call from 100 metres away..... after bits of flywheel landed at the commentary box 8O
Postby frost » Tue Oct 30, 2007 12:27 am
also watch the vid of the green rota on the slide bar do the same thing on a burn out pad, and watch part 2 of the close up damage,
in this day and age its so easy to get a proper after market flywheel, and its not as much as people think you just have to shop around, easy under $500
i guess it comes down to what your using your car for, if its daily then don't even bother, but for anything in the high revs for prolonged periods..
A no-brainer ??
Postby jondee86 » Tue Oct 30, 2007 8:42 am
BZG|Bling wrote:commentator made the call from 100 metres away..... after bits
LOL :D Yeah, and he would be a top man if he also picked it as a
lightened stock unit.
As Frost says, you gotta use a bit of commonsense. Drag racing or
hardcore abuse, and you should be looking at a steel flywheel with
uprated clutch to handle the extra heat.
Cheers... jondee86
Watch this space >>> <<<
jondee86
