3sgte hesitation
Re: 3sgte hesitation
Postby sk8dude » Tue Dec 23, 2014 4:32 pm
Well with the impending requirement to drive the car long distances and during holiday seasons I managed to squeeze my car in to "Hodder Automotive" in Auckland just before Xmas (23rd of December).
They put the car on the diagnostics scanner which read as a misfiring issue.
So they checked the obvious.
The result was :
The spark plugs had had it. The gaps were large, The colouration was off (rusty orange in some cases), One had a crack all the way up the ceramic casing and the type of plugs were not the type recommended for a turbo engine (i.e. cheap plugs). So the plugs were replaced with Platinum type spark plugs
In addition the air filter was full of crap.
I'll be taking the car for a long drives over XMAS so will see how this goes but should hopefully now be resolved. :)
In fairness I should of managed to at least checked the air filter. :oops: My assumptions were that this type of stuff would have been picked up by the previous mechanics when the engine was replaced.
Toyota Caldina GTT Wagon
Auckland NZ
sk8dude
Postby Akane » Thu Dec 25, 2014 12:36 pm
I don't recommend platinum (I'm sure you mean iridium?) plugs for 3S-GTE's. Good'ol BRK7E's that's gapped correctly would be better.
but glad that you have sorted out your issue.
Postby Al » Thu Dec 25, 2014 2:44 pm
Yep NGK BKR6E if the motor is stock, or some BKR7E if it's slightly modified.
Al
