caldina gtt manifold warping problem
Postby gttNICK » Sat Oct 06, 2007 11:48 pm
thanks for explaining everything.
The noises returned after perhaps 2-3 months of the original work
Caldina gt-t
gttNICK
Postby Mr Revhead » Sat Oct 06, 2007 11:55 pm
yep that sounds like a typical planed manifold im afraid.
Postby gttNICK » Sun Oct 07, 2007 12:40 am
so no reason to suspect dodgy helicoils?
Caldina gt-t
gttNICK
Postby Mr Revhead » Sun Oct 07, 2007 12:44 am
its common for manifolds that have been planed to start leaking within 3-6 months.
Postby evil_si » Sun Oct 07, 2007 4:43 am
there is a lot of weight on the studs that are there, unfortunatly the one piece turbo exhuast housing / manifold doesnt help things
does the manifold have a slit between ports 2 and 3? if not and there are bolt holes either side cut a thin 2mm slit right through
make sure all the exhaust mounting points are intact on the entire exhuast, and the bracing from turbo to block is in place,
could be a good idea to put an extra couple in ??
im wondering if the extra bolt hole in the head could be utilised, maybe a piece welded to manifold to use it and replaned or possibly some type of wedge,
evil_si
Postby evil_si » Sun Oct 07, 2007 4:51 am
gttnick, i see in your signature you have a turbo back exhaust,
were is the first support bracket? or mounting point,
particually on these cars and ones with cheap stainless manifolds, there should be one right up the front, within 4-6" of turbo then one under the engine before the flexi.
do you have a decent exhaust flexi?
a little bit of unsupported weight on the actual exhaust system acts as a lever and creates a lot more weight at the turbo end of it
evil_si
Postby Mr Revhead » Sun Oct 07, 2007 9:52 am
evil_si wrote:im wondering if the extra bolt hole in the head could be utilised, maybe a piece welded to manifold to use it and replaned or possibly some type of wedge,
i think it was fivebob a while ago who suggested using that hole for a clamp. and im pretty sure its been done.
Postby evil_si » Sun Oct 07, 2007 10:12 am
sweet, if it hasnt been done might be worth getting some pics together and making a tech post on it.
evil_si
Postby WCKWGN » Sun Oct 07, 2007 12:45 pm
my after market headers just need a tidy around a weld, it hasnt lifted from the head.
pretty rank from toyota it is a design flaw and they are now not standing by there enginering. No matter when it was or wasnt made
to make it one piece with no flange to turbo was stupid. to say it is the end user who contributes to its demise is crap, moving parts like steel wheel or ceramic in the turbo should not be covered as they can be abused through not servicing oils or runnning high unsafe boost ... but some thing that is a manufacturing casting problem and that was fixed on the facelift caldinas, proving there was a fault with what they had done . i think toyota should come to the party of those with pre facelifts and see them right. It isnt fit for the purpose that it was manufactured....being subjected to high heat for prolong useage.
To have the individual shell out money to fix a toyota problem I think is rank
When mine warped it snapped a stud of the manifold , ping up and ripped the protective stuff under the bonnet pinged back onto the plastic cap on the alternator and shattered it..... hmmmm end user fault ??
Mine was planned back by Pitstop and put back on and had no other issues with it and motored on it for another year no probs. I had only 85,000kms. Imported it with 75,000kms.
Mitsi had a problem with there brakes 2 years ago and they recalled the VR4 Galants and Legnums from memory no matter how they got here Liceneced or privately imported they carried out the work needed to be done, so wether it comes off a signiture range Toyota dealership with a stacked price or not shouldnt matter at all as to if they stand by there worksmanship.
To get headers , turbo , fuel regulator, wastegate, ecu - install and dynod tuned, while you are there a FMIC + piping. it is a expensive way to repair some other monkeys mistake.
If it was only as easy as a after marker $600 headers that flanged onto the factory turbo and not have to look at ecus etc etc
my 2c
WCKWGN
Postby Caldina3SGTE » Sun Oct 07, 2007 2:38 pm
just wondering can u just cut the turbo off the manifold and get a new flanged welded on the turbo and then get a new manifold made up to suit?? is that possible?
Caldina3SGTE
Postby mr_monkey » Sun Oct 07, 2007 2:40 pm
Caldina3SGTE wrote:just wondering can u just cut the turbo off the manifold and get a new flanged welded on the turbo and then get a new manifold made up to suit?? is that possible?
Anything is possible if you have money.
Previous rides: 1992 Toyota Trueno, 1992 Nissan GTI-R, 1985 Toyota AW11, 1990 Toyota SW20 Turbo, 1994 Toyota Supra Twin turbo, 1991 Toyota Soarer Turbo, 1991 nissan Safari
Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
mr_monkey
Postby gleem » Sun Oct 07, 2007 5:49 pm
hmmm if yours goes you may as well get a aftermarket turbo and manifold as its around $1600 for a new turbo from mr revhead, you could get a t3/t4 custom manifold and wastegate easily for that much, sure its best to get a ecu and tune it and all but you dont have too.
gleem
Postby lucasthefallen » Sun Oct 07, 2007 7:08 pm
just last year toyota recalled old hilux surfs to replace steering relay rods......
Need Service or Repair work done? send me a PM
lucasthefallen
Postby Zak » Sun Oct 07, 2007 7:28 pm
The do quite a few recalls, mostly steering though.
At the moment, we are doing all the steering column's on all sorts of things, head light switchs on camrys, axles and all sorts.
No chance of them doing the caldinas though, too much labour and parts to do it properly. They are over 7 years old now so they are getting on a bit too.
Zak
Postby strx7 » Sun Oct 07, 2007 9:51 pm
a warped manifold or a snapped stud isn't a safety issues, its not going to kill anyone as a direct result, the steering related things they recall can do.
Postby gttNICK » Mon Oct 15, 2007 10:22 pm
It is in the shop getting fixed as of today(hopefully for the last time). Manifold and turbo came off and helicoils were fine, had damaged the first stud again. Manifold is being flattened, stud replaced and a bracket made up. All turbo and exhaust brackets were fine and in place. Will try and get a pic of the bracket and post up.
Caldina gt-t
gttNICK
Postby gttNICK » Wed Oct 17, 2007 12:16 pm
Car is back and the manifold is silent (for the time being). It had shredded another stud (not the one that was helicoiled last time) and bowed again. The damaged stud was replaced and helicoiled and the manifold flattened. He made a bracket up which he said effectively adds a stud where the one is missing. Have to wait and see I suppose...
Hats off to Magoo Muffler in Dunedin for honouring the guarantee on their workmanship, the only bit I was charged for was the bracket.
And sorry I can't get a pic up, you can't see anything now its assembled again.
Caldina gt-t
gttNICK
Postby Santa'sBoostinSleigh » Wed Oct 17, 2007 1:04 pm
mines done over 160,000kms and is still fine *touch wood*
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Mr Revhead » Wed Oct 17, 2007 1:06 pm
now that you said that it'll let go this weekend!
Postby Santa'sBoostinSleigh » Wed Oct 17, 2007 1:27 pm
can you touch my wood too, just for luck....
i mean you are the one that weaseled your way into my cabin!
car has to pass a wof first, the exhaust is leaking like a b!tch at the back - time for gasket goo me thinks. its freaken pissing down with rain too :(
VTNZ are blind and passed it 6 months ago, but its got a bit worse and knowing my luck they'll ping me on it, just cause i dont have time to fix it
Santa's Mega Sale
