Mr Revhead wrote:dont be too harsh guys...... there are several possibilities here
I wasn't being harsh, but the amount of time to respond is curious. If I had that kind of power out of a 20v I'd be quite keen to show off my dyno plot.
chindrew wrote:thats normal man. You will feel the vvt kicking in around 3500rpm. If you are crusing at around 4000rpm and floor it you will feel the vvt kicking in again at around 5200rpm.
try it out
Mr Revhead wrote:chindrew wrote:thats normal man. You will feel the vvt kicking in around 3500rpm. If you are crusing at around 4000rpm and floor it you will feel the vvt kicking in again at around 5200rpm.
try it out
sorry mate, thats not correct.
VVT doesnt switch on at a set rpm, its tps switched (amoungst other factors)
basicly if the engine is half warm, anything over 1/4 throttle will switch it on.
i guess if you had an aftermarket ecu and set it to switch on at 4000rpm you would feel a kick, as it would be a bit flat untill then
Lith wrote:However you never claimed >130kw @ wheels
