curren roll cage design.
Postby matt dunn » Mon Aug 06, 2007 12:17 am
Simon85MR220v wrote:Ovalised as in no longer round so the tube can be distorted either way. For ease of maths, if your tube was 100mm diameter and was crushed a bit in the bending process, the minimum measurement it can be is 90mm.
Yeah but they way I read it,
when you crush bend a pipe, it flattens off the pipe a bit,
so with your 100mm pipe you may end up with a measurement of 93mm from top to bottom, but will spread to 105mm side to side,
so 105mm x 0.9 is 94.5mm so even though it is 93mm it is still out.
Postby Infinite » Mon Aug 06, 2007 4:21 pm
redmist were does your cage at the rear end up finishing on the strut towers?,
Also got a off cut of roll cage tube and unfortinitly our bender crush's it but lucky there is a guy in town who will be bending it for me in a proper roll cage bender.
Lots
Infinite
Postby fangsport » Mon Aug 06, 2007 6:12 pm
Infinite wrote:Also got a off cut of roll cage tube and unfortinitly our bender crush's it but lucky there is a guy in town who will be bending it for me in a proper roll cage bender.
just get a kit bent up by someone who knows what they are doing, a 6-point kit in steel starts at about $400, less if you only get the bends done.
i have seen many bends done by very experienced guys still exceed the limit on oval-ness.
it will save you money if you waste tube on bad bends.
fangsport
Postby RedMist » Mon Aug 06, 2007 6:35 pm
[quote="Infinite"]redmist were does your cage at the rear end up finishing on the strut towers?,
[quote]
They are plated and end on the backseat facing side of the strut tower.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Infinite » Mon Aug 06, 2007 7:42 pm
the guy who is going todo them owns his own fabrication shop in town and has built many roll cages... and its going to cost me $88 for 5.5mtr length's of roll cage tube 38.1x2.5 i will need 3 lengths, and the guy will do all my bends for $60, so all together not including time this is cheap also will be picking up my plate tomorrow. just sucks cause i start work again tomorrow!!! :(
Lots
Infinite
Postby strx7 » Mon Aug 06, 2007 8:59 pm
are you using Roll Cage tubing or Chrome Molly? If you're using rollcage tubing from steel and tube you are getting tugged on the price. Mine cost me $67 per length
Postby Infinite » Mon Aug 06, 2007 9:33 pm
evan maurice thompson cant get it for that.
Lots
Infinite
Postby strx7 » Sat Aug 11, 2007 6:15 pm
i just rang steel and tube at the mount. the guy i spoke to was a friend of a friend and gave me 10% discount.
