tie rod end ball joint
Postby JRS » Wed Jan 02, 2008 12:55 pm
undo the 2 bolts holding the strut to the hub. this is how every mechanic does it.
meh.....
JRS
Postby Zak » Wed Jan 02, 2008 2:24 pm
If you do it that way you will need a wheel alignment after, if you use the lower one you don't.
Zak
Postby Lloyd » Wed Jan 02, 2008 3:18 pm
Which is why most mechanics do the bottom bolts ;)
