Strange 20V Silvertop Misfire - FIXED!
Postby nmcgowan » Mon Oct 12, 2009 2:39 pm
SN1FTR lives! After draining then dropping out the fuel tank I pulled the pump out. A quick visit to PickAPart confirmed that a 20V pump (or just about any Toyota pump judging from the 3 different Toyotas I looked at) will physically fit in the bracket with a little persuasion. Problem is that the 20V pump has a nice plastic connector for the pump wiring and the AE82 just has round terminal ends that bolt onto the pump. Easy enough to cut the connector off and crimp on the right terminals but I also noticed the 20V pump has some kind of resistor(?) wired into the works, the AE82 doesnt have this. Rather than install it/not install it and have issues later (pulling the tank out is not pleasant) I bought a pump of FXGT Race that I knew would fit. So fitted the new high flow pump and put everything back together...fired her up and blew a hole in one of the high pressure fuel lines that had a hairline crack in it. Fixed that...ALL GOOD, runs like a dream! Infact it has quite a bit more midrange torque but thats probably from resetting the timing.
So thanks to everyone for your help, its been much appreciated. I'll chalk this one down to experience and not owning a fuel pressure gauge. =)
Behold the mighty SN1FTR.
nmcgowan
Postby Crampy » Mon Oct 12, 2009 6:58 pm
Good stuff dude. Good to hear.
Crampy
Postby rollaholic » Mon Oct 12, 2009 8:11 pm
always good to see resolutions being posted too, helps heaps with others searching threads
Postby KwS » Mon Oct 12, 2009 9:09 pm
rollaholic wrote:always good to see resolutions being posted too, helps heaps with others searching threads
Its a rare thing that....
People that ask for help then when its solved, dont say how they fixed it really get under my skin.
Fantastic to hear you got it sorted! you had pretty much changed everything else in the process, so atleast you know the rest of the car should be all good too now, lol.
KwS
Postby solidog » Sat Oct 17, 2009 1:08 am
So have you fitted a fuel pressure guage then?
-=4age inside ~ Allmotor Toyota=-
I know stuff, im modest, I get involved
Yeah newtown ae that me! Did you know "Newtown : Its a bit shit!" but not me!
solidog
Users browsing this forum: Bing [Bot] and 7 guests
