MAGN1T wrote:Moving parts in an exhaust system are always a problem for long term reliability.
That's one of the reasons why wastegates use poppet type valves instead of butterfly valves. Any butterfly valve will eventually jam. GTOs use an "active exhaust" which is a butterfly valve, You won't find one still in working order.
BTW I've built 2 turbo setups without wastegates. Only for lowish power street cars but if the turbo is sized sensibly, they're not essential.Chances are I'll be building another without a wastegate, Only because I can and it keeps the cost down.
Steve
So if i fit a wastegate, will i blow my head gasket?
Man, im confused. Some of you guys are saying smaller WG for more power, but others are saying bigger for more power. Which one is it?
