ST205 fluids
Postby ihavelift » Tue Nov 10, 2009 3:29 pm
sergei wrote:
ihavelift wrote:damage the paint?!?! $&#$% i'm such a noob ... so excust question ... but that won't matter, as long as you're not a spaz and spill it on the car ... right?
EDIT: and what about the Nulon engine oil flush?
Well the right one will damage the paint, if it says that it will not damage the paint it will mean that you got wrong fluid.
Don't use engine flush. It is just plain kerosene. It ruins seals, and sometimes can dislodge sludge that will block oil pick-up line.
$&#$% this i'm getting Dot4. I'm confused.
Current: 2000 Honda Accord Wagon CF6
Previous: 97 Toyota Celica GT4 ST205; 2001 Toyota Allex RS180, 96 Nissan Sentra SG
Low, Slow, Clean and Mean
ihavelift
Postby xsspeed » Tue Nov 10, 2009 3:46 pm
read sergei's links to wikipedia. not too hard to understand.
Dot 3,4,5.1 are compatible with each other alcohol based and strip paint if spilled. Different boiling temps
Dot 5 is silicon based, does not strip paint. Not compatible with leftover dot 3,4,5.1 fluid.
Alternatively look in your owners manual if you have one or look online. Failing that often the DOT rating is marked on the rubber cap of the fluid reservoir.
Users browsing this forum: Google [Bot] and 3 guests
