Farkin 20v idles!
Postby Dell'Orto » Wed May 19, 2010 6:47 pm
Yep standard, and nah, havent checked yet...given its age and K's I'd not be entirely surprised though. Who's got a spare I can borrow so I can pull it out?
Postby blindnz » Wed May 19, 2010 7:18 pm
have you checked the tps? i assume the 20v's are like the 16v?
blindnz
Postby Dell'Orto » Wed May 19, 2010 7:35 pm
No I've done $&#$% all so far, just checked for obvious leaks. Weird that its intermittent/resettable though, and really only comes after on after driving for a certain period.
Postby whynot » Wed May 19, 2010 11:31 pm
Good thing I cary a spare ecu around in the boot... Is it still behaving after we swapped the ecu over?
whynot
Postby Dell'Orto » Wed May 19, 2010 11:37 pm
Yup sure is :D Still takes a while for the cold idle to drop, but its still much smoother and doesnt idle high anymore.
Will try get the ECU out tomorrow and get it to you at some stage :D
Postby Dell'Orto » Fri Dec 24, 2010 11:31 am
Oh yeah, in the end we repaired my ECU, and it idles normally, though with the A/C idle up solenoid connected it will still idle massively high, but with it unplugged its business as usual.
