siren676 wrote:Dude your design and cad skills are very impressive.
If you are able to make this product I will definately buy it. I will give my engine bay a quick measure up in the morning and you can compare it to your 4age one.
Will this design run into the problem of forcing air into the engine and possibly making it run lean?
cheers man. it won't be for a little while my welder is getting fixed atm. i'm heading back to uni next week then guna work every 2nd weekend full time so will probably be the end of march before i get a bit of free time during the week to get into something like this.
yeah as nzhorider said, it won't be enough to upset the AF ratio but if a fresh air feed is fed directly into the intake it could be enough to make the MAP or MAF sensor to get outside its limit of readings, in which case the ecu won't know what to do with itself. its unlikely but always design for the worst. one way of eliminating the risk is to not seal the pipe coming from the foglight going into the front of the airbox
@nzhorider i have yet to see a filter with 'angled' flutes if this is what you are talking about? if you know of any then that could be a possibility.
to figure out the angle at which the increased area becomes more of an advantage than the disruption of the air, it would be a lengthy test procedure as you would have to go in say 5deg intervals, keep airflow constant and measure the pressure on either side of the filter to determine it accurately. not sure if it would make too much difference in the real world cause you could already fit a filter which is much bigger than a std filter anyway.
yeah the pipercross and K&N filters are good 'inline' solutions to isolating your pod but IMO it does not get back to the advantages of having a proper airbox from my research. from analysing what makes the ARC box a good performance airbox, it is purely the volume of air closely available to the engine which gives it the advantage as the actual construction is pretty average with sharp corners everywhere and odd angles. yet it still works. these 'inline' filter isolators do a good job at keeping hot air out but don't give the engine a resoivour of filtered air readily available. if you want to see an example of this, see the design of the 'whale penis' intakes you can buy for honda engines. they work on the same principle and are known to give better response and torque.
