Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
mr_monkey wrote:do you worry about reliability running at high rpm for extended periods?
QikStarlie wrote:i'd be paying allot off attention to the tune, both ignition and fuel wise. over the entire operating range you'l be using. as thats whats going to kill it.
matt dunn wrote:How do you plan on mapping an advance curve without an ECU,
as anything from a non forced induction won't work ignition wise,
and how do you adjust the mechanical injection if it is not right as they are all pre set from factory??
