gt4dude wrote:
as i said the one and only symptom is the overflow and the loss of coolant through overflow, another thing, when its cold theres vacuum in the upper hose, so its spitting out coolant as usuall but not taking it back??
gt4dude wrote:ive driven the car over 70,000 under my ownership, between then and now of hard driving, im not sure that a BHG would have lasted so long and still to this day make good power...
CAMB01 wrote:gt4dude wrote:ive driven the car over 70,000 under my ownership, between then and now of hard driving, im not sure that a BHG would have lasted so long and still to this day make good power...
You shouldnt have a noticable power loss or if any at all with a blown headgasket.
ive seen cars drive for longer with mildly blown headgaskets.
rollaholic wrote:if you have good circulation - top and bottom hoses, heater hoses all very close in temp (too hot to touch for long) - rad good and hot across its core, with the fans clicking in and out at idle - thats a pretty good indication that everything is doing its job.
rollaholic wrote:have you checked the plugs? (looking for brown tips, sign that you are burning water)
gt4dude wrote:...only symptom is the overflow and the loss of coolant through overflow, another thing, when its cold theres vacuum in the upper hose, so its spitting out coolant as usuall but not taking it back??
i was also running a trd 1.3 cap -- would that have helped or made it worse?
gt4dude wrote:could a st205 head gasket be changed in a garage without a hoist or engine lift?
if i can just undo everything under the hood i may just gradually pull it apart myself and send my head away and get a few more kms out of it
gt4dude wrote:definitely blown head gasket, theres no point putting my new radiator in ive got water out the tailpipe and steam and bubbles out the radiator lol
i took the thermostat out and ran it, the water circulates good on idle, i see it swirling well but when i rev it , everything just comes right up the top..
thanks everyone for chiming in, thanks for getting my hopes up i do atleast feel better having tried and observed for myself...
now at 203,xxx with its entire lifetime of overheating problems, would my best option be buying an imported low kms engine or risk opening pandoras box by taking my head off with the engine in the car?
it seems like the problems never end with my engine even with a resurfaced head and new head gasket im sure the next thing to go wrong will be right around the corner... its like cancer,
im sure theres corosion, if theres any narrow water jacket passages they are sure to be cracked, anything that can go wrong with an overheating BHG possibly neglected engine probably has gone wrong or is about to...
