Electrical Q's
Postby johntramp » Thu Apr 20, 2006 10:54 pm
right?
So I wire that to run through a 12v relay to the fan?
johntramp
Postby sergei » Fri Apr 21, 2006 1:14 am
yep, make sure that control side of the relay is grounded through this switch (more ASCII art):
````12V
``│`relay`│-------\
``│t/swtch│``│`FAN``│
(GND)V`````````V
Postby johntramp » Fri Apr 21, 2006 1:18 am
oh I see, so the thermoswitch will ground when it wants the fan to be on?
johntramp
Postby sergei » Fri Apr 21, 2006 1:22 am
yep
Postby johntramp » Fri Apr 21, 2006 1:56 am
does the fuel circuit relay work similar to this?
johntramp
Postby sergei » Fri Apr 21, 2006 9:14 am
I think FC output is 12V so you will have to connect other way arround (relay grounded, while powered by FC)...
Postby johntramp » Fri Apr 21, 2006 10:51 am
that thermostat switch has 3 Ohms resistance to ground, when the engine is cold. That to me sounds far too low...
johntramp
Postby sergei » Fri Apr 21, 2006 11:11 am
Oh, it is inverse to normal switch (On when cold, Off when fan needs to be switched on) the thing is it would draw only 100mA max because it will "power" just a relay, if you are not using stock relay, you will have to use the contacts wich gets disconected when relay is powered.
Postby johntramp » Fri Apr 21, 2006 11:37 am
ok cheers, ill see what i can do.
johntramp
Postby johntramp » Fri Apr 21, 2006 11:59 am
Does it matter what sort of relay I have? As I would guess that it up to the relay to decide when to switch over.
This relay I have here which I hope to use is;
RL- 020
TOYOTA 90987-04002
12V 5P
(last on page http://autolider.com.tw/acc%20parts/electrical%20%20parts/relays/OTHER%20RLY-2.htm)
johntramp
Postby johntramp » Fri Apr 21, 2006 12:18 pm
I just checked the FC output, and it is 2Ohms to ground when the engine is running and then goes up to 18Ohms when the engine stops. There is no voltage out of it at all... so I guess that needs a relay similar to the fan aswell.
johntramp
Postby johntramp » Tue Nov 14, 2006 8:21 pm
Would running the lead from the coil to the distributor alongside the loom through the firewall be a bad idea due to induced currents in the loom? If so, is there an easy way to insulate the lead so I am able to run them together?
johntramp
Postby sergei » Tue Nov 14, 2006 8:24 pm
put it in silicone hose, while loom in earthed metallic braid/foil.
Postby johntramp » Tue Nov 14, 2006 9:58 pm
ok cool, where would be the best place to pick up that kinda stuff?
johntramp
