RobertC wrote:what about this![]()
Affroman wrote:Pod filters dont let the heat in as much as they suggest. Track tested in in the winter at Taupo, intake temperature was 27C. Temperature change is swift too.
BZG|Bling wrote:Affroman wrote:Pod filters dont let the heat in as much as they suggest. Track tested in in the winter at Taupo, intake temperature was 27C. Temperature change is swift too.
Most driving is in town though where engine temps get rather warm sitting in traffic etc, which would have a negative affect on having a pod.
Affroman wrote:Just a quick over view.
On a blacktop, pod filters cost power.
eskimo wrote:So after reading through this thread im better to leave the K&N panel filter in the standard air box over fitting trumpets and socks to my AE111
BZG|Bling wrote: I've had all 3 options and the car felt fastest with panel filter in. Slowest with open trumpets. Only seat of pants dyno though
Kittah wrote:eskimo wrote:So after reading through this thread im better to leave the K&N panel filter in the standard air box over fitting trumpets and socks to my AE111
Yes. Unless you've got an appropriately-tuned aftermarket ECU and other bits and pieces, you will always see a power drop if you ditch the factory plenum.
