DVSMOTORSPORT wrote:Do the fans not come with the little mounting feet that slip in there anymore?
Nah I bought them second hand. Although they were used f'all.
cat007 wrote:And the last pic is showing how much space the fans take up, and how much the shroud is blocking the radiator. To cut this area out, or not to cut it out - that is the question
loudstealthGT-Four wrote:cat007 wrote:And the last pic is showing how much space the fans take up, and how much the shroud is blocking the radiator. To cut this area out, or not to cut it out - that is the question
If you cut bits off the shroud around the fans then you are completely counteracting the whole purpose of the shroud in the first place![]()
Unless you are going to do what Adrian/MrOizo said and make flaps that open at highspeed and close at lowspeed, which is quite a good idea![]()
But seriously I dont see you having any issuses with the setup you've made
cat007 wrote:Ok I think I'm done.
Hopefully you all approve haha.
matt dunn wrote:cat007 wrote:Ok I think I'm done.
Yep, exactly how you'd do it for a burnout car,
and exactly opposite of how you do it on a circuit racing car.
cat007 wrote:matt dunn wrote:cat007 wrote:Ok I think I'm done.
That doesn't make a whole lot of sense.
Sounds like you're saying circuit racing with high air flows at high speed require more cooling than doing a full throttle burnout relying on fans alone
I'm confused....
cat007 wrote:Yeah but what he said doesn't make sense.
A track car would get way more air flow through the radiator than what the fans could produce, even with my current setup?
sergei wrote:cat007 wrote:Yeah but what he said doesn't make sense.
What happens here is that fans generate negative pressure when the car is under the specific speed, while the car over that speed the fans generate drag (even when they are powered on) and act as restriction. Factory shroud is a lot more aerodynamic and thus does not cause that much of a drag. Additionally on many cars the fan shroud only covers half of the radiator.
DVSMOTORSPORT wrote:It will work fine
matt dunn wrote:you have to remember,
99% of the purpose of a factory shround on a modern car is to get airflow through the A/C condenser while stopped at the traffic lights.
iOnic wrote:matt dunn wrote:you have to remember,
Even on cars without AC?
