Nylon rope trick gone wrong
Postby solitaire » Fri Jan 11, 2013 3:31 pm
phoenix wrote:Can you describe the shimmy/vibration in greater detail? If you hold the revs steady at say 2,000 rpm is it constant?
yes 99% sure it is mate, feels like a really light wheel imbalance, more obvious if you put you have on the front fender at idle
AE92, KZJ120, KDJ120
solitaire
Postby RS13 » Fri Jan 11, 2013 4:22 pm
Are you sure all cylinders are firing? Maybe pull the lead off the cylinder that you put the rope down (with insulated pliers!) whilst running, see whether the rpm changes with it on or off.
RS13
Postby solitaire » Fri Jan 11, 2013 4:30 pm
RS13 wrote:Are you sure all cylinders are firing? Maybe pull the lead off the cylinder that you put the rope down (with insulated pliers!) whilst running, see whether the rpm changes with it on or off.
good question, have checked and everything is attached correctly, tried disconnecting some plugs to make sure and everything is good, also sounds perfect at idle.
solitaire
Postby RS13 » Fri Jan 11, 2013 4:48 pm
I'd check the engine/trans mounts next - I read something a while ago about 1UZ mounts being susceptible to cracking.
The timing is bang on? Have you run diagnostics?
RS13
Postby solitaire » Mon Feb 18, 2013 7:12 am
Swapped out the harmonic balancer (over-fortnight parts from japan) and it seems to have done the trick. The old one took a bit of a beating.
Had a few runs up hill at full noise and revs and it's absolutely fine, phew.
So, in summary - never doing that again.
solitaire
Postby phoenix » Mon Feb 18, 2013 6:19 pm
solitaire wrote:Swapped out the harmonic balancer (over-fortnight parts from japan) and it seems to have done the trick. The old one took a bit of a beating.
Through Mark? I didn't know you were looking for a substitute - I have a working condition one here :lol:
phoenix
Users browsing this forum: No registered users and 29 guests
