Blacktops when cold
Postby AceSniper » Wed Jul 26, 2006 6:41 pm
thx for the info will have alook next time im under there
AceSniper
Postby demis » Fri Jul 28, 2006 11:25 pm
sounds like we should do a group buy of o2 sensors :)
EX 1984 Corolla FX GT (AE82) 1st gen 4age
EX 1996 Corolla BZ touring (AE101) 5th gen 4age -LSD
EX 1997 Carib Z touring (AE111) some 4afe muck
Ex 2000 Fielder S (ZZE122)- Its BIG RED
2002 Corolla Ts (ZZE122) Mr ~ Ts
demis
Postby matt dunn » Fri Jul 28, 2006 11:42 pm
demis wrote:sounds like we should do a group buy of o2 sensors :)
We have a good supplier of them through work.
I'll look into it.
Matt
Postby DocT » Mon Jul 31, 2006 7:31 pm
I have a 97 BZG wagon that used to hesitate when cold. I have just changed the o2 sensor and it has cured the problem. It was running rich and and was a bit reluctant to rev above 5K sometimes when warm. The symptoms seemed to come and go a fair bit and didnt return any fault codes until just recently. I had also changed the cap, rotor, coil and tested the leads resistance. Thought the problem might have been detonation but retarded the timing to 8-9degrees (running 98)and it made no difference (seemed to rev a bit more freely). was planning to change the efi water temp sensor if the o2 sensor didnt fix it. I tested the feedback voltage from the sensor when the error code came up and it was >0volts.
DocT
Postby dotdog » Tue Aug 01, 2006 8:00 am
So, what a 02 sensor for the blacktops worth?
Daily Ride - 00 Subaru WRX STi RA 12.7@113
Project Car- 89 Toyota Starlet Turbo S 95.1kws
Ex Ride - 85 Toyota Starlet Si with 4efte, 1990 Nissan Pulsar GTiR 150Kw/atw, 97 Toyota Levin BZR
My Profile: http://toyspeed.blakjak.net/profiles/profile.php?id=589
dotdog
Postby AceSniper » Tue Aug 01, 2006 4:57 pm
revhead does them abit over $100 I think
but we should sus the issue out as iv replaced mine and its back to its old habbits, sometimes works on a real warm day, so I think its todo with carbon buildup and no heat to burn it off, dono just a guess
on a o2 guage it reads lean, so the ecu will be dumping more fuel than needed in making it even worse with unburnt fuel
AceSniper
Postby Mr Revhead » Tue Aug 01, 2006 5:04 pm
ah a little more than $100!
around $220 iirc
i wonder if its an issue with our fuel?
Postby AceSniper » Tue Aug 01, 2006 5:49 pm
ohh haha oops, so long ago iv forgoten what I payed :lol:
AceSniper
Postby astrae » Tue Aug 01, 2006 7:23 pm
Just interested...
Has anyone run any avgas or octane boost?
astrae
Postby ROBODISCO_20v » Wed Aug 02, 2006 11:24 pm
Yep I've run av gas in my black top. Doesnt affect the O2 sensor.
The rep fom shell told me it only affects cat convertors.
ROBODISCO_20v
Postby matt dunn » Wed Aug 02, 2006 11:54 pm
ROBODISCO_20v wrote:Yep I've run av gas in my black top. Doesnt affect the O2 sensor.
He doesnt know what he is on about then.
I run the 4 wire oxygen sensors in my race car with avgas.
You get about 20 hours of accuracy, and after about 50hours tthey are dead.
Matt
Postby 4000GT » Thu Aug 03, 2006 12:16 am
Matt
I have had mixed results with them. I used the Bosch 7057 and it went dead after 30mins of avgas once. The next lasted a few weeks, the last one I had lasted a year! Though they all cant be credited to the avgas, so who knows, it just what happened. The 7057 is a VERY good value WB sensor.
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby matt dunn » Thu Aug 03, 2006 12:20 am
Matt
Not quite what I meant but, close.
4 wires are narrow band. I use them as an indication of mixture, not a tuning tool as WB are.
They are also the exact same sensor that a Blacktop 20V has in it which is why I posted. I use them as I can get 12 narrow band sensors for the cost price of a w/b one.
Matt
Postby 4000GT » Thu Aug 03, 2006 12:26 am
Matt
Matt
I found the NB didnt have enough definition above stoich and richer than 12:1. The influence ambient temp has on them is a little scary in race applications. I guess you could say you get an idea if an injector fails or have a fuel leak etc though
4000GT
Postby astrae » Thu Aug 03, 2006 7:11 pm
I've had 10 litres of av gas through mine mixed with about 30 litres of 98. That was over six months before I started noticing problems with hesitating.
The auto sparky was convinced that would of killed it.
what do you guys think, considering its only 10 litres mixed and didn't have problems till 6 months after?
astrae
Postby demis » Thu Aug 03, 2006 11:27 pm
i still think that the main problem is nz fuel
anyway if any body can get the o2 sensor cheap let me know as i think it i will just swap mine for a new one and see what happens
what sort of fuel consumption are you guys getting with your black tops?
im getting about 12.3 k/L around town giving it death all week :)
demis
Postby catchafox » Sun Sep 10, 2006 12:22 am
I'm having the same problems with my ae101 agze and its bring up the knock sensor as a fault code, could this be a cause of the many problems not just the o2 sensor?
catchafox
Postby matt dunn » Sun Sep 10, 2006 1:10 am
demis wrote:i still think that the main problem is nz fuel
I can do a universal 4 wire sensor for $120 inc if that helps anyone?
Postby I TRD I » Sat Sep 16, 2006 5:39 pm
Mine too only when its really cold though it seems to be happening just when VVT should kick in but
the ECU will not allow VVT to engage at water temp below 50c
i figured this was something to do with it ?
does replacing the 02 sensor really fix it ?
NZ new AE82 GT sedan I TRD I was stolen in january still nothing recovered ! I TRD I is now a notchback ae85 with full ae86 running gear , high comp pistons , hks cams , etc
I TRD I
cold blacktop
Postby stealthFX » Thu Oct 12, 2006 11:06 pm
This seems like a really common problem aye, my 98 BZT carib is doing the same thing..
Does replacing the o2 sensor really fix it? This prob is pretty sketch when ur pulling into traffic aye..
stealthFX
