AE86 Speedo not working
Postby 86 Power » Wed Mar 24, 2004 11:06 am
My speedo has never worked since I got the car. I have tried to find the problem by process of elimination.
The dash is functioning, the cable is complete and operational, the connection of cable to dash is good. The box gear turns when the wheels turn so its ok.
The part that doesn't seem to be happening is the connection of the cable end into the spindle thing at the box. I think the key is not engaging.
I have tried to add a washer with a slit out of it to pull the cable further into the box to help it engage, but that hasn't helped.
Is there a piece missing or something?
86 Power
Postby Xyrath 86 » Sun May 15, 2005 3:59 pm
Did you ever find out why it wasn't working as mine suddenly stopped working last night. First it went wacky and started going up and down and stuff and then just stopped working all together. The cable seems to be attatched corretly.
Xyrath 86
Postby Xavier » Sun May 15, 2005 5:06 pm
could it be the fuse??
Cheers...
My Profile
1999 Altezza AS200 Z
1995 Trueno BZG (Previous)
1992 MR2 GTS (Previous)
Xavier
Postby Silent Knight » Sun May 15, 2005 5:44 pm
Xavier wrote:could it be the fuse??
Are you being for real? Your speed from the gearbox is not measured by a fuse.... :?
Silent Knight
Postby 86 Power » Mon May 16, 2005 9:42 am
When the needle starts jumping up and down, the speedo gear inside the gearbox is skipping a tooth. It is either because the clkip that secures it in places has come free (happened to me) or the gear has been stripped. It is only nylon. Pull it out and take a look, only one bolt. May need to replace. Would pay to change your gearbox fluid also.
86 Power
Postby Xavier » Mon May 16, 2005 11:38 am
Silent Knight wrote:Are you being for real? Your speed from the gearbox is not measured by a fuse.... :?
well it happen to my s14 silvia when the fuse went off, the speedo and tachometer is not moving... :D so i am just guessing it could be the fuse as the speedo meter is not getting reading as it is not powered...
Cheers...
My Profile
Xavier
Postby 86 Power » Mon May 16, 2005 12:06 pm
Yeah, but AE86 have a mechanical speedo.
86 Power
