20 valve AE82 FXGT
20 valve AE82 FXGT
Postby SpeedFReekz » Mon Apr 05, 2004 11:21 am
Would i need to get my car certed because ive stuck a silvertop motor in but its still in the 1600 range just a different variant??
Also would anyone know if the brakes off a AE101 20 valve GT apex fit onto AE82 fxgt struts??
1986 AE82 FXGTR 4AGE20 ...kw atw
Check out my Profile http://toyspeed.blakjak.net/profiles/profile.php?id=486
SpeedFReekz
2
Postby PRYMORTAL » Mon Apr 05, 2004 12:45 pm
onyl need cert for engine if its had the engine mounts and stuff changed and/or a 20% increase in horse power over the factory engines hp rating
best to ring ur area cert guy and ask him on other things ur not sure of tho
PRYMORTAL
Postby ChaosAD » Mon Apr 05, 2004 6:55 pm
but toyota reakons the silvertop is more than a 20% increace :roll:
ChaosAD
brakes
Postby fxgt race » Mon Apr 05, 2004 7:38 pm
I think the brakes will fit but they cannot be of a car with super strut suspension as i hace just tryed these an they are to big.I do have big two pot brakes on the car and i assume they are of levin with normal struts,they are in my race car which ways in at 930kg an with the right brake compound they really hall this slut up.
fxgt race
Postby TRDWGN » Tue Apr 06, 2004 8:35 pm
Superstrut 2 pots can be put on AE82's, caliper bolts up no problem, to put the SS disc's on although you need to get them machined down about 5mm or so.
TRDWGN
Postby event2 » Sun Apr 11, 2004 11:19 pm
wat ya do with ya old 4age blue top i need a going one just motor. no gear box needed.
event2
Postby 2Fast4vtec » Tue Apr 13, 2004 9:36 am
No you do not need a certify it. I have done the conversion and it is sweet. Got any pics? In addition, what is it doing on the quarter mile?
2Fast4vtec
Postby SpeedFReekz » Tue Apr 13, 2004 5:22 pm
I dont have any pics of it at the moment but i will do once the conversion s finished..
Im hoping to stick it down the quater mile when its finished
event2 im keeping the old bluetop and its going to get the turbo treatment and stuck into an KP61 starlet :twisted:
fxgt race Only the front brakes bolt up the same but the back ones need a bit of modifing to fit but yes they do stop yo ass in a hurry :P
SpeedFReekz
Postby Grrrrrrr! » Tue Apr 13, 2004 8:44 pm
Read this... and then decide whether you need a cert or not
http://www.ltsa.govt.nz/publications/vi ... -train.pdf
Grrrrrrr!
Postby SpeedFReekz » Wed Apr 14, 2004 9:32 am
looks like i dont need a cert then...
SpeedFReekz
Postby 4agepwr » Wed Apr 14, 2004 12:27 pm
how hard is the conversion wiring wise?
can you use the bluetop ecu , how much was it to get it wired up?
Jappa AE82 Corolla GT Sedan
EX: AE82 NZ New Corolla GT Liftback
4agepwr
Postby SpeedFReekz » Wed Apr 14, 2004 12:45 pm
No you cant use the Bluetop computer cos it just wont work..
you have to use the 20 valve loom and computer..
the only wires that ive had to rewire are the ones that connect to the EFI relay to the fuze box in the eigine bay and power to the 20 valve computer and starter soleniod and fuel pump
All the sensors that you need to make the engine run are just conected to the computer...
I just sorta figured it out myself through trial and error but its not as hard as it looks
theres plenty of information on the net from other people that have dont simmilar conversions
im sure someone else would have more to say
SpeedFReekz
Postby Mr Revhead » Wed Apr 14, 2004 2:32 pm
read it again, you do need a cert. for engine sustitution it quite clearly states the engine must be the SAME or LESS power, a 20v is more powerful therefore you need a cert. you must meet ALL of the requirements not just some of them.
Postby 2Fast4vtec » Wed Apr 14, 2004 3:41 pm
That is just the LTSA once again trying to outlaw ‘boy racing’. You cannot do shit anymore e.g big bore exhaust systems, alternative cold air box induction systems. According to that legislation, my fx is illegal as $&#$%. And, would not run 14s quarters otherwise. Just do the conversion and find a suitable (pro boy racer) garage to give you a WOF.
2Fast4vtec
Postby voltage » Wed Apr 14, 2004 3:53 pm
im gona get stung bad when i go to get a warrant, ive changed from the 2E carburated motor to the 4E-FTE turbo. Everything was bolt in so maaaaybe i have some small chance of getting let off.
RB26DETT Stagea
ex:A31 Manual Cef
Ex-1990 GT Turbo Starlet
voltage
Postby Mr Revhead » Wed Apr 14, 2004 3:55 pm
if you replace an engine with one from a higher spec model and can prove that the suspension and brakes have been upgraded to the higher spec parts (MUST be bolt on) then you can get away with it
Postby 2Fast4vtec » Wed Apr 14, 2004 4:04 pm
voltage wrote:im gona get stung bad when i go to get a warrant, ive changed from the 2E carburated motor to the 4E-FTE turbo.
Wow, wicked, you actually did that conversion (2E being 1300cc single carb). Those starlets already fly like they are because they are very light. I am thinking about doing that next. How fast is it? It must smoke other GT’s aye?
2Fast4vtec
Postby voltage » Wed Apr 14, 2004 4:23 pm
yeah thats the one, single carb 1300, same motor you find in heaps of corollas and that. Goes better than i thought it would, ive ditched power steering and air conditioning so i suppose that would help a bit, other than that i think everythings the same weight, ive got it looking like a factory GT model now ( ep82 )
RB26DETT Stagea
ex:A31 Manual Cef
voltage
Postby MR2boy » Wed Apr 14, 2004 4:36 pm
u know u could have got a much faster reply if u just rung up a vehicle certifier and asked them
in theory u could get away with it but for the sake of $250 its better to be legal on the road
MR2boy
Postby 2Fast4vtec » Wed Apr 14, 2004 4:42 pm
Kuel. Do you have the GT bonnet (scoop); also do you still have the factory top mount?
2Fast4vtec
