condensation in engine
Postby RandomTask » Fri Apr 09, 2004 7:50 pm
just wondering, recently comming into winter, ive noticed alot more "mayonaise" in the oil cap, is it probable that its beacuse of the colder weather/moister air? or just coincidence and i have a blown head gasket(btw, havent noticed any other symptoms)
RandomTask
Re: condensation in engine
Postby Monsterbishi » Fri Apr 09, 2004 8:35 pm
RandomTask wrote:just wondering, recently comming into winter, ive noticed alot more "mayonaise" in the oil cap, is it probable that its beacuse of the colder weather/moister air? or just coincidence and i have a blown head gasket(btw, havent noticed any other symptoms)
I'd be suspicious, I never have anything other than oil under the oil cap...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby RandomTask » Sat Apr 10, 2004 12:09 am
also its a 4k engine(carb'd), i usually get a wee bit, and i've heard most oldish engines do.
also theres no other symptoms of a blown headgasket, still runs just as well/fast, doesnt heat up any quicker, no water on the dipstick etc etc etc
RandomTask
Postby B_giB » Sat Apr 10, 2004 12:30 am
i would seriously look further into that...
sometimes a blown head gasket wont allways show up all the symptoms, replace it anyway and see if it still does it
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby RandomTask » Sun Apr 11, 2004 7:15 pm
righto ya'll, replaced it, turns out the water had eroded a hole in the gasket so it went into the head where it should'nt have :o
anyway, it runs sweet now, doesnt seem to heat up as much etc, but the tappets are noisy which i guess is understandable seeing it took the push rods out etc
just one thing im concerned about... when i cranked it over using a ratchet on the crank pulley it made a hissing noise like a tyre being let down... is this normal?
thanks
RandomTask
Postby Ae92typeX » Sun Apr 11, 2004 8:11 pm
normal.
Just tha compressed air in the cylinders exiting
Ae92typeX
Postby RandomTask » Sun Apr 11, 2004 8:20 pm
for real bro, thats a relief, it appears ive done a succesful h/g replacement then :D
p.s yeah B_giB i see what you mean now, it wouldny have affected anything else but the water level
RandomTask
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
