couple of questions on DIY jobs
Postby 2fas4u » Tue Apr 20, 2004 9:57 pm
hi all, if you have read my post in the lower north island/wellington sectioned you would have known that my licence has been suspended for six months so now i have plenty of time to do mods on my car (90' toyota mr2 sw20 n/a). now i got a couple of questions on DIY jobs as i know that high cost in vehicle upgrade and maintainance usually gets steep at the labour part so i wanna keep cost to minimum if possible.
here it goes:
1/ if you change brake pads do you need to replace brake fluid?
2/ is it good to have different size tyres at front and rear, i currently have 205/r50/16 at the front and 225/r50/16 at the rear, or should all tyres be the same size?
3/i was told by a different person who i went on a cruise with that my clocking sound coming from the front, mainly right hand side of the car was that the springs needed abit adjusting? that make sense and if so, how do i do that?
4/ thinking of replacing driver's side and passenger's side door locks with solex, but how do i take the old factory lock out? does it requring removing all the internal door panel?
5/ my wing mirrors seem to shake a wee bit while the car is sitting there idle at the traffic light so i thought the screws were loose underneath so i got one of those screwdrivers from repco that is the right fit and try to tighten it but infact teh screws weren't lose ar all, any ideas?
6/thinking of replacing my factory toyota clutches with racing clutches so just wondering how much are new racing clutches? where to get them done properly in wellington?
cheers for any help you can give me and your precious time in advance :)
2fas4u
Re: couple of questions on DIY jobs
Postby aaron » Tue Apr 20, 2004 10:08 pm
i havent done it on this sort of car but itll be pretty much the same you have to remove the door linning and then its just a case removeing a clip that slips in behind the back of the lock and undoing the wires that conect to the locks. put the new lock in and hook them all back up done takes about 10 min
aaron
Postby 2fas4u » Tue Apr 20, 2004 10:25 pm
cheers aaron, i will attempt it on a bright sunny day with plenty of hours to spare:D
2fas4u
Postby Dell'Orto » Tue Apr 20, 2004 10:49 pm
2fas4u wrote:1/ if you change brake pads do you need to replace brake fluid?
Don't have to, but you may as well
YES! MR2's need larger rear rubber! Factory sizes are something like 195/60/14F and 205/60/14R
Nah springs dont need to be adjusted, it could be a worn bush in that strut, hard to say without hearing it
Yep, you'll need to take the door trim off compkletely, it isn't hard at all...getting the lock out could be a tad tricky though
Pretty sure there are screws inside the door to tighten em, you'd have to pop off the tweeter mount to have a looksee
Depends how full on you wanna go...a full paddle type clutch (which would be complete overkill for your car) will set you back around $800+...a decent heavy duty one will be more like $300+...shop around for soem quotes. Don't know any good mechs in welly sorry.
cheers for any help you can give me and your precious time in advance :)[/quote]
Postby 2fas4u » Tue Apr 20, 2004 11:37 pm
cheers brad, good to have someone with pretty much exactly the same car as me to get good advice from :D
2fas4u
