boost in 4agze
boost in 4agze
Postby AE101Z » Wed Apr 21, 2004 3:38 pm
just wondering can a 4agze install a boost controller? and the standard boost of ae101 sc
AE101Z
Re: boost in 4agze
Postby Monsterbishi » Wed Apr 21, 2004 3:41 pm
AE101Z wrote:just wondering can a 4agze install a boost controller? and the standard boost of ae101 sc
Standard boost is around 8psi, and since boost is controlled by the size of the crank pulley, no a controller is not a usefull idea...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Re: boost in 4agze
Postby Banga69 » Wed Apr 21, 2004 4:38 pm
as kinx had already mentioned you cannot use a boost controller on a s/charger. as boost in run by a belt and a bigger crank pulley. so if u want more boost you'l need a biiger crank pulley.
hope that helps
CURRENT:
1994 Mazda Lantis
EX:
SOLD: AE101 GTZ ====>http://toyspeed.blakjak.net/profiles/profile.php?id=89
Banga69
Postby AE101Z » Thu Apr 22, 2004 2:13 am
i have a oversized pulley buy since i installed it my car is slower after 100km/h than the standard. anyone know why????so i just wondering maybe a boost controller will help
AE101Z
Postby Lanius » Thu Apr 22, 2004 7:40 am
Belt slip? Do you hear a squealing noise at all when you go over 4 or 5000rpm?
Lanius
j
Postby 93Levin4AGZE » Thu Apr 22, 2004 8:56 am
maybe not enuf oil pressure.
or as Lanius said, check ur belt.
supercharger belt tend to get loose and dont bite well..
93Levin4AGZE
Postby Banga69 » Thu Apr 22, 2004 11:44 am
how much boost you running?
have you done the ABV?
could be belt slippage.. need some belt grip helps a treat
CURRENT:
1994 Mazda Lantis
EX:
Banga69
Postby IH8TEC » Thu Apr 22, 2004 11:58 am
when i first got my bigger crank pulley and took it for a drive, it felt exactly the same to drive, but then i looked at the speedo and was like damn, it actually does make a huge difference, my has got alot more balls up high now, hope you sort it out man, good luck
brendon
Postby AE101Z » Thu Apr 22, 2004 12:28 pm
Lanius wrote:Belt slip? Do you hear a squealing noise at all when you go over 4 or 5000rpm?
i think that is the problem, so do i just need to change another shorter belt??
AE101Z
Postby aesc » Thu Apr 22, 2004 1:10 pm
Na you just need to adjust the tensioner on the belt
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Banga69 » Thu Apr 22, 2004 1:53 pm
yea your tentioner on your idler pulley and soem belt grip will help, but dont tighten it too much otherwise you'l snap the belt or cause damage to your idler pulley, water pump and a/c pulleys. juts tighten it like half turn then take i for a spin if not tighten it again.
CURRENT:
1994 Mazda Lantis
EX:
Banga69
