fuel lift pump, recommendations???
Postby rxtoy » Tue May 04, 2004 6:26 pm
i need a lift pump for my lancer, high volume low pressure (i think) to get it to the surge tank. any recommendations???? preferably something cheap and/or easily cannibilised from pick a part
also i've got a walbro 255 litre per hour pump for my high pressure pump, but i've just realised that its set up for an in tank pump, is there any reason why i can't use it externally????
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby suckymotor » Tue May 04, 2004 6:53 pm
you could use a fassit red tupe pump about $150 from repco or look for a vn comador one at pick apart
suckymotor
TS Original Member
Postby M R 2 Mk1 » Tue May 04, 2004 7:54 pm
and remember being nick-a-part it will only cost you 1 dollar for that trivial item so you can stick the fuel pump in your pocket
Working Sucks and Thinking is for Losers
M R 2 Mk1
Postby rxtoy » Tue May 04, 2004 9:51 pm
do i need something that specialised? like i was thinking wouldn't most carby fuel pumps do to supply the surge tank and i'd just need a high pressure one afterward??
i was hoping that something like a stock AE85/6 or something equally as easy to find would do the trick
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby suckymotor » Tue May 04, 2004 10:18 pm
dont know about the ae85 one but ae86 is a in tank high pressure
a lot of people use the vn ones in things like rotors i had a fassit red in my ae86 as it was running carbs
suckymotor
TS Original Member
