AW11 Dizzy question
AW11 Dizzy question
Postby Monsterbishi » Wed May 05, 2004 8:03 pm
When you're advancing the timing, which way do you turn the dizzy?
I have a sneaky feeling I've been running on about 0 deg base...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby Ae92typeX » Wed May 05, 2004 10:49 pm
useing a timing light?- you should, dont go by ear. If you are easyenough to see which way to turn when ya do it.
Ae92typeX
Re: AW11 Dizzy question
Postby matt dunn » Wed May 05, 2004 11:08 pm
JiNX wrote:When you're advancing the timing, which way do you turn the dizzy?
Turn the dist in the direction of rotation to retard the timing
and opposite to advance.
You need to bridge the check connector and have the idle contacts closed to set it correctly.
Matt
